Labvie Plots wrong way round
I have an 8 channel board connected via sine generator so connections made through BNC connector , so V1-V8 are channels and Plot 0-Plot 7 are the plots for the channels mentioned respectfully.
V1,V2,V7,V8 are all correct giving plots for Plot 0,1,6,7 . thats fine. However V3-V6 are the problems.
so V6 should be Plot 5, V5--->Plot 4, V4---->Plot 3, & V3---->Plot 2
instead i am getting :
V6=Plot 5
V5=Plot 2
V4=Plot 5
V3=Plot 4
Any idea where to start here?
PS. the picture (excise poor colour for graph) is when the connection is made to V3 so so should be Plot 2 to see it, instead it is Plot 4 I have to click.
Message 1 of 13
(4,158 Views)
*correction*
V6=Plot 3
V5=Plot 2
V4=Plot 5
V3=Plot 4
Message 2 of 13
(4,139 Views)
Could you diagnose why a car is not running from looking at the color of the car?
Rolf Kalbermatter  My Blog
Message 3 of 13
(4,137 Views)
apologies, but was thinking this may have been a common problem.
Message 4 of 13
(4,128 Views)
Hi dhanna,
the "common problem" here are people asking questions and only providing a picture of the front panel.
No block diagram picture/snippet, no VI - but expecting solutions for their problems…
Message 5 of 13
(4,121 Views)
Let me rephrase what the others are saying.
If you post your VI, we can help you find your problem.  It is likely a stupid wiring mistake, but we can't tell you that until you give us something to look at that will enable us to figure out what your problem is.
GCentral
Message 6 of 13
(4,100 Views)
Also the common problem here is that there are many things that could be going wrong. But there ends the common cause of such an error.
You don't mention the actual hardware you are using nor the possible accessory hardwares that you may be using to convert your DAQ hardware outputs to BNC connectors. And as Gerd said, you show a front panel only without providing the diagram at all, or much better even the actual VI you wrote.
Possible reasons include errors in your wiring from the hardware to the BNC connectors, mislabeled BNC connectors, your cabling to the BNC, wrong setup of the configuration for the 8 channels and probably a few dozen other things. Assuming that the problem lies in LabVIEW is in 99% of the cases simply ignorance of the possibility to make errors yourself.
Message 7 of 13
(4,097 Views)
there would be a lot of screenshots involved!
Message 8 of 13
(4,093 Views)
Zip files with the actual VIs would be best.
GCentral
Message 9 of 13
(4,090 Views)
probably be tomorrow before i get around to that
Message 10 of 13
(4,078 Views)
