Labview 7.1 crashes on Ubuntu 7.04! Help!
Hi! I want to install Labview 7.1 in Ubuntu 7.04. My procedure is the following:
1) Log in terminal as root
2) Convert rpm to deb with "alien -d -c"
3) install deb packages either with "dpkg -i" in terminal or with "GDebi Package installer"
The problem is that when I try to run the application (installed in /usr/local/lv71), Labview seems to open (actually, a window appear exaclty as it used to happen in Windows environment), but after 1 minute or so, it just closes. Am I doing anything wrong? What is happening here?
Thank you very much for your help!
Cheers,
Diogo Montalvão
(Lisbon, Portugal)
Message Edited by dmontalvao on 09-05-2007 05:33 PM
(2,655 Views)
I'm sorry, but you must know that LabVIEW is not supported on this distribution; It may work, but we can't affirm it will ...
Here is a link to the linux supported distributions.
Regards
Richard Keromen
(2,610 Views)
