Labview Community 2020 Edition Activation
Somewhere it maybe mentioned, but for certain, I would have saved a few hours if it was clearly written in the community edition page, that we must be logged into our account when downloading and installing. Additionally it could be mentioned that this is to allow the NI License Manager to automatically include and update for the community edition, no serial number needed, which would remove our experience from the past clouding the way into the future 🙂  Thanks for this thread which made the install possible!
Message 21 of 123
(5,499 Views)
I didn't think you could download something unless you were logged in!
Message 22 of 123
(5,488 Views)
I think what this means is that you can't download it on one account, then try to activate it on a different one.
Bill
CLD
(Mid-Level minion.)
Message 23 of 123
(5,482 Views)
That is true.  But why would someone have more than one NI account?  Particularly a new user just starting out with the community edition.
Message 24 of 123
(5,479 Views)
I have (had? Might have?) 3 different NI accounts. I could see problems with existing account holders if they don't pay attention ... like down loading CE "at work" then taking it home and trying to install it. (IE work vs home account)
Former Certified LabVIEW Developer (CLD)
Message 25 of 123
(5,473 Views)
When I attempt to use the recomendation to find a serial number for the comunnity edition, it states no serial number.
is there another way to generate an activation code for offline? my machine that i am tryign to install on cannot connect to the internet. I installed by burning the download to a disc.
thank you.
Message 26 of 123
(5,403 Views)
Hi ChiefOfRocketSurgery,
At this time, you must be connected to the internet to activate LabVIEW Community Edition. We are working on improvements to allow for offline activation in the future, but it isn't available with this release.
Mackenzie
Message 27 of 123
(5,395 Views)
I just installed LV2020CE on my shop/lab computer in a remote building that has no internet connection ... after downloading the iso file to my main computer while logged onto my NIUA. LV2020CE is listed on My Products page with no serial number showing.
I now have the same problem ... no way to activate LV2020CE installed on a pc with no internet connection.
The NI License Manager activation screen on the target pc tells me I can get an activation code at ni.com/activate using the Computer ID showing onscreen ... but this is not possible without a serial number, which does not exist for LC2020CE.
Unless NI fixes this issue to allow activation without a serial number for a different pc without internet access, then my only option is to get temporary internet access for the target pc so I can log onto my NIUA from the computer I want to activate. My WiFi does not reach the shop building, but maybe I can use my phone data link as a hotspot to get temporary access to ni.com ... or haul the desktop pc to a location with internet service.
I do not expect NI to fix this issue anytime soon, so I will enable temporary internet access one way or another from the target pc and get LV2020CE activated.
No additional response from NI is needed or expected. The other post stated that LC2020CE MUST be activated with logon to NIUA from the target pc ... with no other options possible for the time being.
Message 28 of 123
(5,348 Views)
Wish I could help you.  😞
Bill
CLD
(Mid-Level minion.)
Message 29 of 123
(5,345 Views)
I successfully activated LV2020CE on a non-internet-connected desktop pc using the following simple procedure:
Tethering Android
Tethering means sharing the Internet connection of an Internet-capable mobile phone with other devices. ... Android phones are already equipped to provide this
 functionality. Simply connect the USB cable and go to Settings -> Wireless settings -> Tethering -> Tethering USB.
After tethering to my phone, I was able to logon to my NIUA directly from NI License Manager on the target pc and successfully activate. (No need to use an internet browser.) I think it's a requirement that you previously downloaded the LC2020CE iso file while logged onto your NIUA to get LC2020CE to show up on your My Products listing.
I presume the same procedure will work for LVNXGCE ... which I also intend to install and activate (iso file already downloaded).
You must connect the USB cable to your phone first, otherwise the Tethering USB switch is greyed out. I think I recall seeing a note that this USB Tether does not work from a Mac target. No idea if/how it works with iPhones.
Message 30 of 123
(5,325 Views)
