Labview Display message and control Value
@Meratus wrote:
Thank you ! But i need to change the value if i change of scenario
If you are setting the Disabled property, you can just do a drag on the property node to allow writing to additional properties. One property you will want is the Value property.  If you aren't setting the Disabled property at the same time, use a local variable to write to yoru controls.
Message 11 of 11
(312 Views)
