Labview Drivers for Wireless Sensor Networks
Hi shawn00,
When setting-up MIB520, did you follow all the steps listed here?
Also, this is an old thread and you might receive more traffic if you create a new thread regarding this issue.
Jordan G.
LabVIEW Product Marketing Engineer
Message 141 of 154
(2,678 Views)
Hello, Jordan!
Yes, i do think the mib520 connects the computer well. Since i can see the port works fine in device manager and i can use MoteView to see the sensor data from nodes.
I also tried some other testing Vis posted by others in this forums. LabVIEW cannot detect the port either. BTW, i am using LabVIEW 2013.
Thanks.
Message 142 of 154
(2,669 Views)
Hi shawn00,
Do you have MoteView and LabVIEW running at the same time? According to this thread, having both programs open at the same time can result in errors.
Jordan G.
Message 143 of 154
(2,641 Views)
Hello sir,
I would like to know , in this MTS400.vi  which u exaplain above.How we add GPS through which we fetch latitude , longitude and GPS time for a node.
Please help me in this
Message 144 of 154
(2,627 Views)
Hi monabhalla,
Could you please explain what you're having trouble with? If you are looking for the drivers for the MTS400, you can find them here.
Rick C.
Message 145 of 154
(2,585 Views)
Hello sir,
i would like to aquire GPS position that is latitude and longitude in Read data and display health.vi.
How we do further programming in labview to aquire latitude and longitude in existing program that is Read data and display health.vi or MTS MDA 300.vi which you attach in above comments. My program is aquiring 10 parameters thats is temperature , humidity, intersima pressure etc. but with this how we develop code for GPS. so that it aquire node position in that vi.
thanks and regards
Mona Bhalla
Message 146 of 154
(2,543 Views)
Hello Mona Bhalla,
Your questions are related to programs that were written several years ago and are 3rd party examples that we may not be able to support. In order to better help you, can you please tell me:
What hardware are you using specifically?
What version of LabVIEW are you using?
Do you have the GNSS toolkit?
Warm Regards,
Josh
Message 147 of 154
(2,512 Views)
Hello sir,
I am using LabVIEW 2013 and using crossbow motes to acquire temprature ,humidity , intersema pressure , light etc data.
I do not have any  knowlodge about GNSS Toolkit. But i have GPS Antena of crossbow. please give me some ideas how we can do further programming in Read data and Display health.vi to aquire latitude and longitude. or either  give some demos examples.I really need your help.
Thanks & Regards
Mona Bhalla
Message 148 of 154
(2,503 Views)
Hello Mona Bhalla,
Unfortunately, this device is not supported by NI, so our resources are limited regarding examples. Your best bet may be to contact the company. If I can find any examples from my colleagues, I will be sure to post them.
Warm Regards,
Josh
Message 149 of 154
(2,494 Views)
hello sir
please you can provide example for fetching lat, long for crossbow XMesh WSN. In above comments you have already gave answers how to fetch data like temp, humidity. But i just want further programming in that.
Message 150 of 154
(2,487 Views)
