Labview Evaluation software Setup problem. "merged.bin" missing. Help!
If you follow the link I provided, You'll end up on a working download page. Works for me.
Where do you see a broken link?
Message Edited by altenbach on 04-21-2008 12:39 AM
Message 11 of 22
(1,932 Views)
altenbach wrote:
To download LabVIEW 8.5 evaluation, please go to the following link:
[link removed]
This link is ok!
Mike
Message 12 of 22
(1,930 Views)
ftp://ftp.ni.com/labview_85.exe
am reffreing to this link, is this working for you?....
I tried both http and ftp to download, but it's giving an error.
regards
Arun
Message 13 of 22
(1,920 Views)
Hi Elxsi,
no this link doesn´t work, but where is the problem, use the other one, submitted from Altenbach. Smiley Happy
Mike
Message 14 of 22
(1,918 Views)
the link submitted by Altenbach ultimately refferes to the same link what i have given....Smiley Sad
Message 15 of 22
(1,913 Views)
Hi Elxsi,
that´s true, but if i follow the instructions on the web site it works. Smiley Happy
Mike
Message Edited by MikeS81 on 04-21-2008 11:05 AM
Message 16 of 22
(1,910 Views)
Hi
 I browsed the Ftp site and found a 1.4 gb .zip, in evaluation folder, i suppose this is LabVIEW..
but it says embedded, is this the same PC labview? or some thing diffrent.
Arun
Message 17 of 22
(1,905 Views)
No, that's different and not what you want.
If you follow my link and use internet explorer to download the 8.5 evaluation, it will work. (The file is password protected, so typing the plain ftp link manually will not work because the credentials do not match).
What browser do you use?
Message 18 of 22
(1,879 Views)
Hi Altenbach
Am using IE 7.0 as browser, am unable to downlaod the file using the ftp link, so as per the trouble shooting I tried using http insted of ftp,
but i get an error saying this page might have been moved.
Message 19 of 22
(1,865 Views)
This will not work unless you also provide credentials. IE7 is a bit better at hiding username and password, so what you see in the status bar when hovering over the link is only part of the story and will not work as typed (ftp, http, ot otherwise).
I have absolutely no problem downloading using the link shown in the picture (you get there after following my link above).
Are you behind a corporate firewall? Some block downloading of executables. In the unlikely case that you are behind a NAT router with incomplete ftp ALG, verify that your advanced IE setting has passive ftp mode enabled? If it is enabled, also try with "passive" disabled.
What are your browser security settings? Are you running a personal firewall or other security software? What is your antivirus?
Message Edited by altenbach on 04-22-2008 08:56 AM
Message 20 of 22
(1,852 Views)
