Showing results forĀ
Search instead forĀ
Did you mean:Ā
Labview FPGA
-I am using myrio 1900 device. I want to genarate 1000 samples per second with (-10,+10) range
-I have attached the VI file.
-I want to have same results with osiloscope via myrio 1900 device.
Message 11 of 14
(1,512 Views)
I'm very confused by the (single) VI you attached.  Here are some questions:
  • Why did you compress a single VI?
  • Why did you use RAR for compression?  Windows allows us to open .ZIP files, and many (most?) of the Forum users don't have RAR "expanders".
  • The VI you attached is a Control and Simulation Loop that builds a 3D Graph.  What does this have to do with a myRIO and FPGA?
Message 12 of 14
(1,495 Views)
  • I have  commpressed this single file before for file sharing propeses.This file was already compressed.I just realized that I must not share this file like this.
  • I want to reprogamme my VI with FPGA VI  and get same results.So I am trying to find a way to programme in FPGA VI.
  • it is very hard to desing my project in FPGA VI from scratch.So I am trying to find a closest way to programme in FPGA VI signal results that I already get.  I want to this with array fucntion.
Message 13 of 14
(1,481 Views)
Hi tahatas,
LabVIEW-FPGA comes with several example projects and VIs. They also explain how to transfer data (including arrays) from RT host to FPGA target!
Yes, LabVIEW-FPGA requires quite some changes in behaviour (aka programming style), including special handling of arrays and (just SGL) float values…
Message 14 of 14
(1,474 Views)
