Labview GOOP for Excel
The easiest way to avoid this problem, you can add an empty array constant to your 1D array with build array, so the dimension for the Excel Easy Table.vi is now correct and empty values are not written to your Excel sheet.
Regards.
Message 11 of 12
(1,048 Views)
I managed to do what I wanted.
But now I struggle with the macro to do a screenshot of cells filled with data in a specific sheet....
Message 12 of 12
(1,024 Views)
