09-06-2013 04:53 AM - edited 09-06-2013 04:54 AM
Hello fsap,
After re-reading your original post and the later comments it seems like you are you trying to make some kind of Remote Desktop Application.
In that case using a Remote Desktopping tool might be useful.
09-06-2013 05:17 AM
I,
I have used this aplication, but because my IP is not fixed i can't conect to the aplication.
Can you help me fixing my IP?
Regards
09-06-2013 07:05 AM
To know your current IP:
- Open the Command Prompt window and type "ipconfig".
- This should give you back your IP-address.
- Check if you can connect to your application
To fix an IP-address of a PC you can use the following steps:
http://digital.ni.com/public.nsf/allkb/D537B986BC064CCB8625774B0060D1C0?OpenDocument
Please make sure that you are "allowed" to use a specific fixed IP-address on your current domain.
If you don't know, then you should check with your IT administrator.
09-07-2013 08:36 AM
Hi Thierry C,
Thanks for Help.
I will try and i give to you an response come soon.
Thanks.
09-15-2013 07:22 AM
How do I lodge a page from a server labview and it has a password for access.
greetings
09-25-2013 07:12 AM
Hello fasp,
I was on Holiday the last two weeks.
What do you exactly want to do?
Do you want to log data to an ftp-site?
