Labview Remote conection and acquire sound and image
Hello fsap,
After re-reading your original post and the later comments it seems like you are you trying to make some kind of Remote Desktop Application.
In that case using a Remote Desktopping tool might be useful.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 11 of 16
(660 Views)
I,
I have used this aplication, but because my IP is not fixed i can't conect to the aplication.
Can you help me fixing my IP?
Regards
Message 12 of 16
(657 Views)
To know your current IP:
- Open the Command Prompt window and type "ipconfig".
- This should give you back your IP-address.
- Check if you can connect to your application
To fix an IP-address of a PC you can use the following steps:
http://digital.ni.com/public.nsf/allkb/D537B986BC064CCB8625774B0060D1C0?OpenDocument
Please make sure that you are "allowed" to use a specific fixed IP-address on your current domain.
If you don't know, then you should check with your IT administrator.
Kind Regards,
Message 13 of 16
(650 Views)
Hi Thierry C,
Thanks for Help.
I will try and i give to you an response come soon.
Thanks.
Message 14 of 16
(643 Views)
How do I lodge a page from a server labview and it has a password for access.
greetings
Message 15 of 16
(617 Views)
Hello fasp,
I was on Holiday the last two weeks.
What do you exactly want to do?
Do you want to log data to an ftp-site?
Kind Regards,
Message 16 of 16
(592 Views)
