Labview Time Setting
After saving the data in the file. CPU time and data file time is not matching. how to sort out the problem? how to execute the exact run time in the output file.
(3,014 Views)
Maybe you need correct local/UTC time?
(3,005 Views)
How are you trying to save the cpu time in data file?
CLD Using LabVIEW since 2013
(2,992 Views)
Can you share your code for how you are saving the data?  Specifically the CPU time.  It does sound like you are storing UTC time while the file time will use whatever local time zone you are in.
(2,977 Views)
Could it be the difference between LabVIEW timestamp and OLE time format?
=== Engineer Ambiguously ===
(2,958 Views)
