Labview crash while remote debugging (load vi form packedlibrary)
Labview crashes when I try to remote debugging my Application.
I load vi's from packedlibrarys after open the vi reference labview crash! This problem exits only with remote debugging.
The effect is reproducible on different systems, installations.
Has anyone any idea or known this problem?
Best Regards
Sämi
(1,851 Views)
Hi samsi,
I have found articles where the solution is well described. Try to go through those articles to solve the issue.
Error Log File Location after LabVIEW Crashes - NI
Troubleshooting LabVIEW Crashes - NI
Regards)
________
The best way to show appreciation for someone's help is to give them Kudos or mark their response as a solution.
(1,703 Views)
Accepted by samsi
Thanks for your answer. Ich checked this problem also with NI and the conclusion was that this is unexpected behavior of Labview. Here is the answer from the NI Support:
After some research, we came to the conclusion, that this is unexpected behavior and I will file a corrective action request.
As soon as it has a CAR number assigned I will share it with you to track its status in the future release notes.
As there is no known workaround for that issue for the moment you will have to debug the VI's one by one before including them in the Packed Project Library.
I already opened a bug report.
The CAR number is 1983809.
(1,697 Views)
