Labview equivalent of Excel's "SOLVER"
I've learned how to solve non-linear equations in Excel using Solver.  Is there something equivalent in LabView?
I have an equation:
T = 1 / (A + B*lnX + C*lnX^2 + D*lnX^5)
Where T is temperature and X is resistance of a thermistor.
Now I'd like to (iteratively) solve for X.
I've looked around the mathematical functions and haven't found anything that sounds like what I'm looking for.
Thanks in advance.
- Paul
(4,812 Views)
Accepted by Pablo1961
(4,793 Views)
you can solve it using formula node
on your Labview BD, right click>>Programming>>Structures>>Formula Node
see here
or;
Programming»Structures»MathScript Node
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
(4,779 Views)
I want the reverse... to compute expected resistance at a given temperature.
(4,719 Views)
THANKS!, that's exactly what I needed.  The documentation was a little sparse but that VI did exactly what I needed.  It wouldn't converge when I started at 1, but it did when I started at 100,000, for whatever reason.
Once I expressed my equation with a zero, on the left, I entered:
1 / ( 0.00112766979300187 + 0.000234444184128213* ln(c) +  8.47692130592308E-08 * ln(c)^3 + 1.17512193579615E-11*ln(c)^5 ) - 273.15 -  25
into the formula text (where the 25 is the input variable and is concatenated into the formula string each time).
And that worked.
(4,711 Views)
