03-23-2017 03:48 PM
I have built a Labview DLL (labview 2014 32b) and have tested it on my development PC by writing a CVI (2013) app around it. I provided it to a customer and instructed them to install the labview 2014 SP1 runtime engine. I also gave them my CVI app (they installed the CVI RTE). When they try to launch the app they get an error that the app "requires a version of 2014 (or compatible) LABVIEW Run-Time Engine." The lvrt.dll is copied to the directory with the app as I had seen suggested in other forums.
The error described above seems to be generated from the LVRTE dll. It is reported with a "System error 317 while loading LabView Run-Time Engine"
I have duplicated this issue on a clean PC of my own, installing the CVI RTE and the LABVIEW RTE.
Does anyone know why the RTE will not load? Is this a common problem?
Solved! Go to Solution.
03-23-2017 03:51 PM
I've attached the error
03-23-2017 04:30 PM
How old was the forum post you read that said that copying the LVRT DLL would be good enough to include the run time engine?
I ask because while I can't seem to find the link right now, I remember reading that at one point that did work but it later stopped working sometime around when LabVIEW switched from version numbers to yearly editions (i.e. 2009ish). I think the LVRTE requires support files you only get by doing a full install on the PC, not just a DLL copy.
03-23-2017
04:45 PM
- last edited on
08-21-2026
09:06 AM
by
Content Cleaner
You need to be more specific with that statement
Only #1 is correct in this case.
03-23-2017 06:07 PM - edited 03-23-2017 06:08 PM
I cannot be sure of what the customer installed. However, when I setup a new PC (to be sure that I wasn't using the full development engine on my development pc). I installed the 32b version, as in your option 1. I Also installed the CVI 2013 runtime, since my app was developed in CVI2013.
I only copied the lvrt.dll from the "C:\Program Files (x86)\National Instruments\Shared\LabVIEW Run-Time\2014 directory", once the above mentioned install was done and I verified that it would still not run. That didn't work either.
03-24-2017 01:02 PM
Does anyone have any suggestions?
03-24-2017 02:49 PM
So did you develop the DLL in LabVIEW 2014 with SP1 or without?
03-24-2017 07:29 PM
What happens if you don't copy the lvrt.dll?
03-27-2017
10:18 AM
- last edited on
08-21-2026
09:07 AM
by
Content Cleaner
I was able to solve this. I needed to uninstall the version:
https://www.ni.com/en/support/downloads/software-products/download.labview.html#306311
and install version
https://www.ni.com/en/support/downloads/software-products/download.labview.html#359539
I also had to remove ANY lvrt.dlls from the project folder where the executable ran. There is an old forum that suggests this.
What is confusing is that if I run NI MAX in the station I built the DLL it states that it has LV 2014 SP1 f1.
