Labview "Tab" under string function
I have a string constant of data in 3 longgggggggggg columns, I have to seperate out the columns by enabling "tab"  to see the values of the data.
Does anyone have any solutions on how to create this?
Message 1 of 19
(6,820 Views)
-Provide Sample data to explain the question better along with VI/LabVIEW snippet.
-Are you going to read from file? What is the format of the file?
-You can check Read From Spreadsheet File VI:https://zone.ni.com/reference/en-XX/help/371361J-01/glang/read_from_spreadsheet_file/
uday
Message 2 of 19
(6,816 Views)
Sorry about it, forgotten to upload the vi.
Basically given the data file I have provided, the string should come out in 3 "tabbed" columns.
The formate of the file is just a text file.
Message 3 of 19
(6,804 Views)
- Use Read from Text File Function to read the file and provide file path to the respective file path.
- Use Spreadsheet String To Array Function to convert to data to array of data.
- Refer the example provided here for reference:https://forums.ni.com/t5/Example-Code/Extract-Column-from-Text-File/ta-p/3524861
- You can exclude the Array subset since you need all columns of data.
Edit: P.S. Sorry on mobile, can't see VI if possible post snippet using : https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2PkCAI&l=en-US
uday
Message 4 of 19
(6,789 Views)
Basically, from the snipped photo I have shown, I have to make the 3 columns into seperate tabs using block diagram components.
Message 5 of 19
(6,779 Views)
Use "Spreadsheet String To Array Function" to convert to string to tab delimited array data.
-Connect String to "spreadsheet string" input
-Connect %s to "format string" input
-Connect 2D array of String constant to "array type" input.
uday
Message 6 of 19
(6,766 Views)
Great option! I chose the "read spreadsheet" and eliminated my previous vi to get this as shown on the snipped photo.
Now, as you can see I have 3 columns, and i have to plot the 3 columns on a xy graph, say:
Column 1 vs Column 3 ,
Column 2 vs Column 3,
Column 2 vs Column 1,
I tried to build the xy graph component a shown, but I have no idea how to link it. Any solutions to that?
Message 7 of 19
(6,763 Views)
-Check examples provided along with labview: Help-> Find examples-> Search for XY Graph.
-I believe you definitely need to learn about LabVIEW. Please try below free online material :
Start with below links to learn about LabVIEW programming
NI Learning Center
NI Getting Started
-LabVEW Basics
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
LabVIEW Graphical Programming Course
uday
Message 8 of 19
(6,757 Views)
Message 9 of 19
(6,745 Views)
Message 10 of 19
(6,731 Views)
