Labwindows to Labview programmming
@GerdW wrote:
Hi Anand,
Is there any tool available to convert Labview vi to .c source code. This for my understanding going forward.
There is a tool(kit).
But I guess you don't want to pay >10k$ just for "going forward"…
If you've already paid $5k for a LV pro license, maybe another $10k isn't such a big deal.  😉
Bill
CLD
(Mid-Level minion.)
Message 11 of 14
(1,036 Views)
I never needed this toolkit but NI offers it.
Well, the OP can always call its local NI sales rep and ask for price and availability…
Message 12 of 14
(1,034 Views)
I just want to expand on one little part of the truly excellent summary from BowenM.
Use sub-vis regularly.  Even though each sub-vi is a separate file, think of them in terms of functions rather than files.
Another incredibly useful feature of subvi's that I tend to take for granted after years of using them is this:  you can open and run them all by themselves, and you'll already have a gui available to let you change the inputs and observe the resulting outputs!
   It doesn't matter if it's a subvi that's several layers of calls below the "main" startup vi.  You can open it and run it all on its own.  And you *should*.  Making each small simple subvi work correctly as it's being built saves untold amount of later debugging in the bigger, more complex full application.
-Kevin P
Message 13 of 14
(1,022 Views)
There is.  It is not useful as a learning tool.
The code produced by the c generation toolkit is technically c (it will compile!), but is programmatically generated stack based c.  This means it is efficient, etc but not exactly human readable.
The c generation toolkit also doesn't support a lot of LabVIEW's core functionality such as event structures, timed loops, and cluster data types.
Message 14 of 14
(1,004 Views)
