Laptop for data acquisition
I am looking for a good laptop for instrumental analysis (money is not an issue). The laptop would need to be fast as it will be connected to a data acquisition system (lots of channels) and LabVIEW.
Would someone be able to recommend a good one?
Thanks.
(4,581 Views)
Accepted by cmfl
Hi cmfl
Typically you'll be OK with anything i7 16GB RAM (even i5), you can pick up a decent laptop from dell for just under 1000USD. If processing power is a concern, maybe RT CDAQ systems or CRIO is more suitable.
I always go for dell laptops or towers with i7 16GB ram, or if the need is there Amplicon industrial PCs.
Regards
Jono
(4,527 Views)
There is no special requirements for LabVIEW beyond the minimum system.
Windows
  Run-Time Engine Development Environment
Processor
Pentium III/Celeron 866 MHz (or equivalent) or later (32-bit)
Pentium 4 G1 (or equivalent) or later (64-bit)
Pentium 4M (or equivalent) or later (32-bit)
RAM 256 MB 1 GB
Screen Resolution 1024 x 768 pixels 1024 x 768 pixels
OS
Windows 10/8.1/8/7 SP1 (32- and 64-bit)
Windows Server 2012 R2 (64-bit)
Windows Server 2008 R2 SP1 (64-bit)
Disk Space 620 MB 5 GB (includes default drivers
from NI Device Drivers DVD)
As for brand and model, with computers in general you get what you pay for so just pick one from a trusted brand.
=== Engineer Ambiguously ===
(4,506 Views)
How about this rugged  Toughbook by Panasonic
PANASONIC TOUGHBOOK CF-29 INDUSTRIAL RUGGED LAPTOP, SERIAL, WIFI
(4,474 Views)
