Large gap around VI/exe window (set to run as maximized)
Hi all,
I'm having the following issue with LabVIEW 2018, and am wondering if others are having it / if it's been fixed in future versions:
I configure my main GUI VI to run Maximized on the primary screen. For some reason, in both development and runtime, there's a big gap around the sides and bottom of the window (about 12 pixels). See attached screenshot for example. The only possible workaround is to make the window resizable and try and set it the window size automatically by fetching the screen size from windows and so forth - not my favorite idea especially since stuff moving around as the window scales usually doesn't go well.
Anybody have some insight? Thanks in advance,
Michael
Message 1 of 11
(3,371 Views)
Sounds suspiciously like a variant of this issue.
Bill
CLD
(Mid-Level minion.)
Message 2 of 11
(3,298 Views)
I agree, except this is far more annoying, because you can see a good deal of the window(s) behind and I’ll even miss the “x” button and open the window behind by accident sometimes, because it’s not in the corner where it should be.
It just makes the application look unpolished and I know my client will be unhappy.
Message 3 of 11
(3,279 Views)
I totally agree!  I wish I had a solution.  😞
Bill
CLD
(Mid-Level minion.)
Message 4 of 11
(3,272 Views)
Hi Michael, can you attach the VI with everything stripped out, but still exhibiting this issue?
Message 5 of 11
(3,244 Views)
Hi
Message 6 of 11
(3,237 Views)
@michael.lambert wrote:
Hi
OMG.  That's all I have to say about it.  😞
Bill
CLD
(Mid-Level minion.)
Message 7 of 11
(3,230 Views)
Wow, my first impression is that if you don't allow the user to resize the window, it's almost as if they just remove the border area where the user would place the cursor when they want to resize the window.
Even a couple pixels is still very annoying though...
Message 8 of 11
(3,225 Views)
Accepted by michael.lambert
I was able to reproduce in LV 2020 as well. I was able to make it look pretty "normal" by trimming 10 pixels off of the left, right, and bottom borders as below. Still not very nice that you have to manipulate the window to simply show it maximized, and I'm not sure how this works with multiple monitors.
Message 9 of 11
(3,198 Views)
I saw that solution once before, I think. The only downside to it, is that the minimize/maximize button will indicate that the window isn't maximized if you programmatically change the bounds. If the user clicks it to maximize, then you're back at square one.
Sooooo, my workaround for the time being is make it non-resizable and move the left, bottom, and right bounds as you've done here.
Thanks for your time and thoughts
Message 10 of 11
(3,185 Views)
