Log test data into single file (CSV format)
i need to log data from 2 sources i.e temperature and voltage into 2 columns separately in csv file format. sources is manually defined i.e numeric control.
sample of file being attached.
I tried to log data using build array concept but data comes in same column. Kindly suggest how to distinguish inputs while writing into file.
Message 1 of 12
(6,268 Views)
You've shown us an Excel file with no actual data.
You haven't shown us the VI you have written that isn't doing what you want.
Please attach your VI, otherwise we can't determine what you are doing wrong.
Message 2 of 12
(6,256 Views)
Message 3 of 12
(6,231 Views)
You still haven't attached your VI.
Message 4 of 12
(6,228 Views)
Message 5 of 12
(6,183 Views)
That's a jpeg screenshot, not a VI.  But fortunately it shows what the problem is.
Why did you pick a carriage return/line feed as the delimiter for the Write to Spreadsheet File?  That creates a line break between every element.  You should be using either the default tab character, or a comma.
There is no reason to have a 1 iteration For Loop.  Just create a 1-D array of your two elements, and wire that into the 1-D array input of the Write to File funcion.
Message 6 of 12
(6,163 Views)
Message 7 of 12
(6,160 Views)
i need to input data manually, how can i put data into 1 D array and wire them to write function. and i need data in two column.
Message 8 of 12
(6,157 Views)
By following the directions I gave.
See attached modification.
Note: I had to change the browse settings for the path control so that it would be new or existing files and not just existing files.
Message 9 of 12
(6,154 Views)
second input comes in first column ; i need to move to 2nd column.
Message 10 of 12
(6,134 Views)
