Log test data into single file (CSV format)
@abinash_bam wrote:
second input comes in first column ; i need to move to 2nd column.
That is because you are using TAB for the delimiter.  If you are going to save it as a CSV, you should use a Comma.  After all, you are making a Comma Separated Values file.
Message 11 of 12
(715 Views)
That's because you saved it with the CSV extension so opening in Excel looks for a comma delimiter.
If you saved it with a .txt extension and opened in Excel, it would be in two columns.
Quote from Message #6
"You should be using either the default tab character, or a comma."
Message 12 of 12
(710 Views)
