Unfortunately I was unable to find a driver for this exact instrument at http://ni.com/idnet. This leaves you with one of a couple options. It may be possible to modify an existing driver to work with this instrument.
There is a driver for the
Hart Scientific 1575 and 1590 Super Thermometers I would first call Hart tech support and ask what the difference between the commands sets of the two models are. If they are unable to give a good answer, then I'd try to get the manuals for the devices just to compare the command sets myself. If they are very similar I'd just modify the old driver. If they are very different, and I was using Lab
VIEW I'd just make I/O assistant VI for each function in the manual, and I would have a low-level driver. Once you have this low level driver you can just combine functions to make higher level VIs.
You can also contact the Hart to see if they have a driver for their instrument. If they do not, you may want to hire an Alliance Member to write an driver for you.
Alliance Member Directory
http://www.ni.com/alliance/alliance_member.htm
Message Edited by Support on 01-02-2007 01:27 PM
