Looking for LabVIEW driver for Agilent ESA-E4405B for Phase Noise MODE Application
I have the Agilent ESA - E4405B (Spectrum Analyzer) with Phase Noise Application Mode on it.
I can control the spectrum Mode successfully but  i can't config the instrument to diffrent mode (i.e Phase Noise Mode) with the "apesa.llb" driver.
I am looking for LabVIEW driver for:
1. To config the instrument to diffrent Mode (i.e. 1.Spectrum Analyzer, 2.Phase Noise).
2. Sets of LabVIEW command for the Phase Noise Mode Application.
Thanks from Advance !!
(3,189 Views)
Good morning raaaz,
It's been a few years since I last worked with the Agilent S.A.  We did Phase Noise measurements with both the Agilent as well as R & S analyzers.
I seem to recall that on the Agilent, we needed an application sw which would do the phase noise calculations and they were not part of the Labview drivers.  It was called seperately after taking measurements.  Of couse this is already ~5yrs ago...  and my memory is fading on the matter..
I will look around and post anything I find in this thread.  I think Dennis may have experimented with Agilent & phase noise measurements.
JLV
EDITED PORTION:
I found a thread from 1 year ago on the subject.  it is for a different model, but basically looking for the same info... or drivers.  Unfortunately, from the posting, nothing was available.
http://forums.ni.com/ni/board/message?board.id=140&message.id=7786&query.id=10496#M7786
You may want to contact the Agilent Rep.  The one I dealth with was extremely helpful and knowldgeable.  The rep may also have access to some "non-public" drivers.  You may also be able to call functions from the dll in order to do the phase noise calculation within Labview.
Sorry, I could not help further.
JLV
Message Edited by JoeLabView on 03-27-2006 09:26 AM
(3,186 Views)
Thanks very much for your fast answer.
Its look that the other guy look for the same think but on diffrent instrument.
The link in his answer are broken - brings me to ni drivers search.
I feel that there must to be some driver - if any one can help on it i will be very thankful.
(3,181 Views)
Hi raaaz,
Although you probably have these, here is the link to the latest drivers on Agilent's website:
http://adn.tm.agilent.com/index.cgi?CONTENT_ID=2619
You may also check with their "Code Samples" and "Knowledge Library"
I will take a look at the Knowledge Base in this website to see if there is anything helpful.
JLV
(3,172 Views)
Link to the NI - Drivers:
http://sine.ni.com/apps/we/niid_web_display.download_page?p_id_guid=E3B19B3E94EF659CE034080020E74861
but nothing mentionned for Phase Noise
However, there is an example in this link for doing phase noise measurements for the National Instruments PXI-5660 vector signal analyzer.  Maybe it can be modified for the Agilent.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=F137417285CE26FEE0340003BA7CCD71
Message Edited by JoeLabView on 03-27-2006 11:23 AM
(3,169 Views)
