Looking for information about the LabVIEW compiler.
Like more about the how type propagation algorithm works with shift register and more.
Any Ebook, videos and white paper?
Hemant
Message 1 of 8
(3,728 Views)
Message 2 of 8
(3,726 Views)
When LabVIEW makes copy of the data.
Branching wires always make copy of the data in LV?
Hemant
Message 3 of 8
(3,720 Views)
@jg69 wrote:
https://www.ni.com/en/support/documentation/supplemental/10/ni-labview-compiler--under-the-hood.html
Regards, Jens
This tutorial i have gone through. Looking for more details info like typing rules about the shift register or how type propagation algorithm works in details and other algorithm.
Hemant
Message 4 of 8
(3,720 Views)
Hi Hemant,
I joined your other question into this thread as it basically asks the same about compiler internals.
The compiler is NI-stuff, I don't think you will get much more information than what is presented in the LabVIEW help and in those tutorials…
Why do you need all this information?
Message 5 of 8
(3,697 Views)
@GerdW wrote:
Hi Hemant,
Just curious to know about how LV internal works and how LV makes data copy and other details.
Message 6 of 8
(3,688 Views)
Accepted by LV_COder
@Hemant_LV
There's a full copy and shallow copy. Shallow copy occurs when then branches represent the same data (Both points to the same block of memory). Full copy occurs when the branch data is modified. Also, there's differences between the "Data Buffer" (Which is the byte cost of some datatype), "Transfer Buffer" (Which is the nodes, branches, wires and so on referenced by the "spatial lifetime on the VI") and the "Terminal" (Which is the controls/indicators) on the front panel. This also known as copy and write mechanism. Dunno if this happens to all datatypes and all cases.
Anyway, you can always use the "Show Buffer Allocations" and "Performance and Memory" on the Profile menu to get some insights.
Some useful links:
https://www.ni.com/docs/en-US/bundle/labview/page/vi-memory-usage.html
https://www.ni.com/docs/en-US/bundle/labview/page/memory-management-for-large-data-sets.html
http://www.ni.com/white-paper/9386/en/
Message 7 of 8
(3,675 Views)
Only when needed. So this is very difficult to predict. Tools>Profile>Show Buffer Allocations gives a good idea. There are several stages working together. The BDHP (block diagram heap) is split into chunks, and is eventually converted to DIFR, and then LLVM. The LLVM compiler converts to assembler, but also performs optimisations. These are, I'd assume, out of control of NI developers, and there is no feedback AFAIK. So it's not hard to come up with examples where a copy will be a required, but a lot harder to prove the will or won't be a copy.
Absolutely most definitely NOT. That would be ridiculous (not the thought, but the resulting program).
Assume a copy is only made when needed. Worry about it iff (if and only if):
1) You need top notch performance.
2) You are dealing with huge data structures.
3) You're trying to understand when LabVIEW makes copies.
Where 1) and 2) are appropriate in the wild, 3) is just to validate this thread.
Message 8 of 8
(3,647 Views)
