Looking to Search and Sort String Twice, though am having issues
Having a bit of a problem with every column after the 2nd column.  For this particular sort each model contains 8 columns of particular data for that particular model (column 1).  Looking to keep this data attached to the model when doing the 2nd sort via the model #.
I've attached the sub-vi to give a better look at this.
Any thoughts?
Message 11 of 15
(767 Views)
Looking at your SubVI I assume that the number of columns is fixed.  In that case, you could do something like this.
Message 12 of 15
(752 Views)
I must have had clusters on the brain, this is good for any number of columns.
Message 13 of 15
(742 Views)
Very decent solution.  Thanks Darin.
How would you implement sorting for.... per say the 5th column or 3rd column?
Message 14 of 15
(724 Views)
To sort on a different column I would typically build a cluster with that column and original index to produce a key which I then use to shuffle the array.
To do more complex sorting I'd probably go green.
Message 15 of 15
(715 Views)
