Lookup Table 1D no sign
I want to create Lookup table using Control Design Simulation toolkit (Lookup Table 1D). Why when I select the VI (Lookup table 1D) from the functions palette it does not carry the VI? I use full liciense Labview software. Anyone expert please advise me..thank you
Message 1 of 23
(4,372 Views)
I am also facing similar problem. I am using licensed version of LabVIEW 2012 on PC with Windows 7 (64-bit) installed.In my case all three VIs (1D,2D,3D) are not working.
Could you sort out the problem?
Arihant
Message 2 of 23
(4,199 Views)
What do you mean by "not working"? What version of LV are you running; 32-bit or 64-bit?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 23
(4,195 Views)
Do you also have a license for the toolkit? Maybe it was installed in evaluation mode and it now expired. Just guessing....
Message 4 of 23
(4,192 Views)
I am using labVIEW 32-bit.
By "not working",i meant to say that whenever I try to drag and drop the lookup table pellet on block diagram it refuse to appear.
Message 5 of 23
(4,180 Views)
@altenbach
I have licensed copy of "control design and simulation" toolkit installed.
The pellets appear on Block diagram>>Functions>control design and simulation>>simulation.
But when I select any of them and put on block diagram, symbol of forbidden appears.
Kindly suggest any reason and remedy.
Message 6 of 23
(4,178 Views)
What happens if you find the VIs on disk and double click on one of them to open them directly?
MIke...
LabVIEW Champion
Message 7 of 23
(4,171 Views)
I couldn't understand you properly. Which VIs?
If you meant any VI, yes they open and run succesfully.If you talking of a VI in which lookup table pellets are embedded, I have not tried any such example.
I will find one and run and then we will see if it works that way.
Thanks anyway.
Message 8 of 23
(4,153 Views)
I'm not sure what you mean by "pellets", but yes if you can find a VI that alreadty has them in it, we might be able to find out what the problem is by trying to open it.
Mike...
LabVIEW Champion
Message 9 of 23
(4,138 Views)
Smiley Very Happy
Hi Mike
I am attching image file with this post which shows lookuptable pellets (or VIs or functions).
I tried finding VIs which use this function but couldn't. If this function works on your system, kindly create an example and post.
I want to see if it works on my PC.
Thanks.
Message 10 of 23
(4,118 Views)
