Losing data along wire when not in Highlight Execution
I don't have LV2018, but last I checked, you can't put two probe points on the same wire.  Anyone have a clue what's happening here?
Message 11 of 33
(1,539 Views)
Good catch - unless this has changed in LV2018 (why would it) it looks like you have two wires overlapping.
Message 12 of 33
(1,530 Views)
I don't think I do? I've attached a version that's even cleaner and showing the same problem.Losing Data 3.png
Message 13 of 33
(1,512 Views)
Something is pointing to a wiring problem with the double probe.  When I open your VI, I don't see an extra wire that could cause a double probe.
Use Block Diagram Cleanup tool on your diagram.  If there are overlapping tunnels or wires, they should jump out.
There is no need for a separate tunnel to exit the while loop to go to the indicator.  Just use the output of the shift register.
Message 14 of 33
(1,510 Views)
Can you save for a prior version?
Message 15 of 33
(1,509 Views)
Just for clarity, place a probe on the Action wire as well.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 16 of 33
(1,503 Views)
I think the probe thing is a red herring.  In fact, it's not even incorrect.  I believe wires are different across structure boundaries, since the values could be different from one side to the other.  (Tunnels/SRs.)
Try triple-clicking a wire to see if you can select anything "on the other side" of a boundary and you'll see what I mean.
Bill
CLD
(Mid-Level minion.)
Message 17 of 33
(1,491 Views)
Try double-clicking a wire to see if you can select anything "on the other side" of a boundary and you'll see what I mean.
I believe you're looking at the wrong image - the one on the prior page (post 10) shows two probes on what appears to be the same wire.
Message 18 of 33
(1,485 Views)
They are referring to the picture in message #10 where probes 2 and 4 "appear" to be on the same wire in the same structure, i.e. between the case structure and the while loop.
Message 19 of 33
(1,483 Views)
In either case, unless its a duplicate wire, as others have said it is most likely a race condition. In whatever case you are passing out the default value, replace that with a 'test' string constant, and put a breakpoint in that case. I would bet it is being called from somewhere you aren't expecting.
Message 20 of 33
(1,480 Views)
