10-18-2018 11:04 AM
I don't have LV2018, but last I checked, you can't put two probe points on the same wire. Anyone have a clue what's happening here?
10-18-2018 12:05 PM
Good catch - unless this has changed in LV2018 (why would it) it looks like you have two wires overlapping.
10-18-2018 01:02 PM
I don't think I do? I've attached a version that's even cleaner and showing the same problem.
10-18-2018 01:04 PM
Something is pointing to a wiring problem with the double probe. When I open your VI, I don't see an extra wire that could cause a double probe.
Use Block Diagram Cleanup tool on your diagram. If there are overlapping tunnels or wires, they should jump out.
There is no need for a separate tunnel to exit the while loop to go to the indicator. Just use the output of the shift register.
10-18-2018 01:05 PM
Can you save for a prior version?
10-18-2018 01:23 PM
Just for clarity, place a probe on the Action wire as well.
10-18-2018 02:13 PM - edited 10-18-2018 02:14 PM
I think the probe thing is a red herring. In fact, it's not even incorrect. I believe wires are different across structure boundaries, since the values could be different from one side to the other. (Tunnels/SRs.)
Try triple-clicking a wire to see if you can select anything "on the other side" of a boundary and you'll see what I mean.
10-18-2018 02:16 PM
Try double-clicking a wire to see if you can select anything "on the other side" of a boundary and you'll see what I mean.
I believe you're looking at the wrong image - the one on the prior page (post 10) shows two probes on what appears to be the same wire.
10-18-2018 02:17 PM
They are referring to the picture in message #10 where probes 2 and 4 "appear" to be on the same wire in the same structure, i.e. between the case structure and the while loop.
10-18-2018 02:21 PM
In either case, unless its a duplicate wire, as others have said it is most likely a race condition. In whatever case you are passing out the default value, replace that with a 'test' string constant, and put a breakpoint in that case. I would bet it is being called from somewhere you aren't expecting.
