Low Sampling Rate Issue with PN2271 Pressure Sensor and NI 9203 in LabVIEW
I'm currently working on a project where I'm interfacing a PN2271 pressure sensor, which outputs a 4–20 mA current signal, with an NI 9203 current input module. I'm using LabVIEW for data acquisition and processing.
However, I'm encountering an issue where I'm only able to achieve a sampling rate of approximately 30–45 readings per second. This is significantly lower than the expected performance of the NI 9203 module, which supports up to 200 kS/s.
System Details:
  • Sensor: PN2271 pressure sensor (4–20 mA output)
  • DAQ Module: NI 9203 current input module
  • Software: LabVIEW
Issue:
Despite the NI 9203's high sampling capabilities, I'm limited to 30–45 samples per second. I suspect that the current LabVIEW configuration might be the bottleneck.
Request:
Could someone provide guidance on how to optimize my LabVIEW setup to achieve higher sampling rates? Specifically:
  1. Should I transition from using the DAQ Assistant to DAQmx VIs for better performance?
  2. Would implementing a Producer/Consumer architecture help in this scenario?
  3. Are there any example VIs or tutorials that demonstrate high-speed current data acquisition with the NI 9203?
(849 Views)
Accepted by mp777
#1 - yes, ditch the DAQ Assitant and use DAQmx APIs to achieve the highest possible sampling
#2 - mostly yes, producer/consumer helps if you got a lot of processing or logging, you can skip producer/consumer if using DAQmx's inbuilt TDMS logging
#3 - checkout datalogging example that ships with DAQmx, those are generic and works with almost all models.
Santhosh
Soliton Technologies
(832 Views)
Accepted by mp777
If you post your code we can give more specific advice to improve the code.
Tim
GHSP
(790 Views)
Subject: Help Needed: Low Sampling Rate Using NI 9203 + PN2271 in LabVIEW Project (Please Review and Correct VI)
Hi everyone,
I’m currently working on a LabVIEW project to acquire pressure data using:
  • Sensor: PN2271 pressure sensor (4–20 mA analog output)
  • DAQ: NI 9203 module
I’ve built a VI (Main.vi) to acquire sensor data using the DAQ Assistant, but I’m only getting 30–45 readings per second. I want to achieve a much higher sampling rate, closer to the potential of the NI 9203.
What I'm Doing:
  • Data acquisition is in Data read.vi
  • No Producer/Consumer loop yet
  • Not using TDMS logging
  • Saving to file is done manually
I received helpful suggestions from the community:
  1. Replace DAQ Assistant with DAQmx API to unlock better performance.
  2. Consider Producer/Consumer for efficient separation of acquisition and logging.
  3. Use DAQmx TDMS logging examples which are efficient and scalable.
Request:
  • Could you please review the attached VI set?
  • Please help me understand how to modify or restructure my VI to:
    • Improve sampling rate
    • Correct any bad practices
    • Implement DAQmx properly
    • Optionally include Producer/Consumer if needed
I’d also appreciate a corrected version of my VI (if possible).
(762 Views)
