MKS PR4000 CONTROLLER driver for labview 8.6
OK, let me tell something new. Now, it runs properly the drivers from the german website. It seems that I have to set the instrument in remote control via command RT,ON and then try run any LabVIEW driver. But it still can't run your  components. I hope that I can do what I want with the german drives.
To conclude, I want to control the setpoints for both channels in relation to specified time stamps and read back the flow (for check).
Message 31 of 80
(2,092 Views)
You still did not answer, whether you tried to use my lvlib in a way as I showed in the snippet in my previous post. Did you try exactly what I have showed? Do you see any error code? My lvlib only uses the drivers which you should have already installed in your instr.lib folder under your LabVIEW installation. This driver is inside the zip file which I have posted previously.
So, did you try the above steps? Can you show your own VI, how you try to use my example? (Init device, Read actual flow value, close device comm).
So did you try exactly this snippet after properly unzipping the driver under your "instr.lib" folder?
Message 32 of 80
(2,083 Views)
Yes, I did exactly what you did in your snapshot. It shows no error but it doesn't read the value. It's strange since I also have noticed that your library is based at the components of the german website. I unzipped your library  in the proper destination (instr.lib) inside a different folder from the library of the german website. I will post tomorrow the snapshots to make yu sure about that.
Message 33 of 80
(2,067 Views)
Message 34 of 80
(2,042 Views)
I see, it is strange, i thought this model should work with it...no idea, if there is no error msg...could you put an error indicator after the Close VI? Maybe there is a warning?. Can you try to set a new SP using my VIs? Does'nt work either?
Message 35 of 80
(2,028 Views)
OK, I am happy to say  that I have figured out what's happening. I solved it.
I had set the instrument's parity=NONE because that's what BZajec wrote in the first page. But your vis and the german website's vis run with parity=ODD. So setting my instrument's parity manually to ODD, solves all problems. It's working fine now!!
Also, I have figured out that I have to run the initialize vi firstly in order to proceed with the other vis. I didn't expect that, I was expecting all the vis had a sub vi for initialize.
Thank you Blokk for your assistance. I would like to ask you why you made your vis? Didn't the german website's were practical?
Message 36 of 80
(2,019 Views)
I told you, you must use the "initialize VI" first! 😛
Anyway, I am happy it works now, you see, I was sure this model must work 😉
And why I made my VIs? Have a look at them. They wrap the device VISA references inside a Functional Global Variable. So I have a more tidy block diagram when I use these VIs, no ref wires going through my MAIN block diagram... 🙂 And some other benefits...
This is something which I have learned in this forum between many other useful things. Beside never ever trust any "official driver", often they are not only impractical, but may contain bugs!
http://forums.ni.com/t5/LabVIEW/Community-Nugget-4-08-2007-Action-Engines/td-p/503801
"Wrap it up":
http://forums.ni.com/t5/LabVIEW/Community-Nugget-4-08-2007-Action-Engines/m-p/503804/highlight/true#...
Message 37 of 80
(2,009 Views)
Thank you again for your support. As for why I wrote yesterday that the german vis ran and yours not,  maybe it is because  I can control the parity easily in the front panel and I put it to NONE, something that I had to dig more inside your code to control.
When I manage to complete my vi, I will post it to help anyone who wants to control the pr4000's setpoint according to predetermined time periods.
Message 38 of 80
(2,003 Views)
Why do not you just use the default settings on your PR4000?
It works for me without any problem, with my own VIs.
Actually my VIs just use the official driver, in a more compact way, as I already noted.
Below is what my Initialize VI uses, just the default settings of the driver Init VI.
Just being curious: what if you set your hardware according to this? Does it work then?
Message 39 of 80
(1,990 Views)
Yes of course it works if I adjust the instrument according to the settings of the VI. The problem was that the instrument had parity=NONE and the VI had parity=ODD. It works either if I change the instrument's parity (manually), or if I change the parity of the VI to the instrument's. I''ll keep parity=ODD as it's the setting that the manual suggests for RS232.
Message 40 of 80
(1,979 Views)
