Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
MMS Gateway
MMS Gateway
Fuquey
Member
01-24-2007
03:13 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
If I want to send MMS or receive MMS from Labview, what sould be needed?
0
Kudos
Message
1
of 2
(3,166 Views)
Reply
Re: MMS Gateway
CKap
NI Employee (retired)
01-25-2007
10:12 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You can probably use a webservice to do this. I havent done it myself, but you can refer to the links below.
If you have LabVIEW 8.2 then you can use the Web Service Import Wizard to create VIs for that particular WSDL.
http://www.aql.com/site/devel_soap.php#soapsendmmsnot
http://www.pswin.com/_pswincom/Documents/SOAPMMS.pdf
or you can refer to
this
link also.
Hope this helps.
Chetan K
AE-NIC
0
Kudos
Message
2
of 2
(3,142 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
