MOXA, RS-485, ModBus RTU
@Gadjetins wrote:
EDITED:
It seems that the API you have is a bit older than mine.
Anyway, try to use:
- Create Modbus Instance (with all serial configuration shown on my picture)
- Read Holding Registers
From Utility, select Set UnitID.vi
- Shutdown (please attach help description of that VI, I'm not sure what it does)
Message 31 of 52
(1,672 Views)
Message 32 of 52
(1,655 Views)
You gave us two oversized pictures with not explanation as to what they show.
One appears to have an error, but the picture doesn't show it.
How are these supposed to help us help you?
Let's regroup here.
Tell us what your current problem is and provide the actual VI that demonstrates it.  We won't be able to run it because we don't have your Modbus device, but at least we'll be able to poke around at it.
Message 33 of 52
(1,651 Views)
I'm trying to get data from the instrument in labview
The device as it seems to me for some reason does not respond to requests
I apologize for the poor presentation of information, I'm very tired of what I can not do.
Message 34 of 52
(1,639 Views)
What version of LabVIEW you use?
Message 35 of 52
(1,634 Views)
2016
Message 36 of 52
(1,620 Views)
Why do you have BaudRate set to 9600?
As far as I remember, you had successful test with external tool on 57600.
Set proper baudrate and test again...
Message 37 of 52
(1,616 Views)
The fact is that I have two devices that I connect to MOXA they have different speed (both work on Modbus RTU Protocol) so in the example there may be a different speed, but the error when connecting these devices is the same.
Message 38 of 52
(1,594 Views)
Извиняюсь, не мог ответить раньше
Message 39 of 52
(1,593 Views)
@Gadjetins wrote:
I think I'm lost. I'm tired of guessing what are your communication parameters. Attached code (test2.vi) has different settings than the picture above.
If you want us to help you I need you to provide all communication parameters.
Otherwise I'm done here.
Message 40 of 52
(1,581 Views)
