MSP-GANG Programmer Compatability
I have upgraded from LabVIEW 2017 to 2024 version and as I am upgrading my previously saved source code, I ran into an issue with the dll used for communication with the programmer;  Find The Shared Library Name "GANG430dll".   I have Texas Instrument's "MSP-GANG Programmer" installed onto my PC but I am not sure if I need to install something else, or if this is even compatible with this version of LabVIEW (2024).  any insight would be appreciated.
(391 Views)
Does the "MSP-GANG Programmer" install directory (probably somewhere in Program Files or Program Files (x86) ) contain the DLL?  I would start by checking there.
(370 Views)
Hi Dark,
Did you change the bitness of your LabVIEW installation?
Is that DLL provided for 64bit or 32bit environments?
(342 Views)
it looks like I had the dll in the wrong directory.  Moved it over to where my code was calling this out to and it worked now, thanks !
(322 Views)
