MY SUB VI DOESN'T WORK.
I'm creating a sub VI, where there's a radio button related to a boolean case and there's an another boolean case under it. in these cases I put the main commands and functions with their local variables. so, when I use this as a sub VI when I'm changing from case to another it doesn't work for example case 1:
x * my = z case 2:
z / x = my case 3:
z/y = x each time a case selected there is one command must not change, but it should give the result
(3,225 Views)
That is probably because Your third radiobutton doesn't have a name, and the Case You've assigned to it only runs when the " " (Space) radiobutton is activated. Try to make the labels of each radiobutton visible, and give each one a unique name.
Don't forget to rate a good Answer....
Here should be some cool signature
But there's NOT
LabVIEW 2012-2017
(3,219 Views)
I TRIED TO DO SO. BUT THE NAME OF EACH CASE TURN RED IN THE DIAGRAM
AND IT DOESN'T WANT TO COMPILE
(3,156 Views)
Accepted by sam2017
No need to yell (all caps = yelling).
Right click on your radio buttons and select Visible Items->Label.  Edit those to match what you want in your case selector.
(3,148 Views)
thank you. that what i did
right click on the radio button => property => modify visible item
(3,134 Views)
