Make A Project
Is there someone Who can make project for me? I really can't get this programm to make it on my own.
Thank you!
(4,317 Views)
google "labview programmer for hire" or something like that
Certified LabVIEW Architect
(4,294 Views)
Are you talking about creating a LabVIEW Project (meaning a Project file, .lvproj, which helps you organize, say, a few hundred VIs, TypeDefs, documentation, Icons, etc. into a coherent set of folders and provides a structure for creating Executables)?  If so, type "Create LabVIEW Project" in Google and you'll find links, including to the LabVIEW Help.
(4,219 Views)
Thank you for answer but No.
I am making a school project and I need to show it in labview for more points. I have discription and simple visual how it should look.
(4,212 Views)
Are you asking for someone to do your homework for you? That will not happen. Are you asking for help with specific questions? You will probably get help with that but no one will do the work for you.
Mark Yedinak
LabVIEW Champion
(4,209 Views)
Accepted by ALWO
Ah, then you need to learn LabVIEW.  There are some links to Tutorials and to Learn LabVIEW on the first page of this Forum.  Since you are in school, there are probably classes you could take to learn LabVIEW.  You will have to put a little effort into it (or you could "cheat" and hire someone to do it for you, but that will, in the long run, not benefit you ...).
(4,207 Views)
If we do the work, we get the points, not you. Right?
Make sure you understand the purpose of points, extra credit, and grades.
(OTOH, I am willing to do it for $15000. (See also) :o, or maybe not....)
(4,169 Views)
