Making a Array controlled list?
Hi
I am trying to make a pull down list in labview similar in manner to a webpage pulldown list found in "internet explorer" or any web browser.
I would like the contents of the pull down list to be that of the array. I have invested a lot of time trying to figure this problem out, however I have failed to come up with a solution.
I would greatly appreciate any help.
 Philip
(4,040 Views)
 To clarify,
 If I had a 1-D array of length 3, with values {"amber","alert","alligator"}
The resulting pulldown list would look like this
amber
alert
alligator
 (note it should look internet explorer pulldown style) Thanks
(4,029 Views)
Look at a combo box.  There are two property nodes, StringsandValues[] and also Strings[] that allow you to programmatically define the lists that go into that combo box.
(4,019 Views)
Thanks, I am making progress.
Any idea how to fix this problem? I saw this working in an example. In the labview example, the pink rectangle above "StringsAndValues[]" was blue. How do I make it blue? Thanks.aasd.JPG
(4,009 Views)
I would like the combo box to output the array location
(4,004 Views)
Hi Doom,
when switching on the context help for that property you would see that it requires an array of cluster of 2 strings...
What do you mean by "array location"? If you want the index of the choosen string you have to do a 1d array search through the array given by property "String[]" (or through your array of strings, as you want to set those strings anyway).
Message Edited by GerdW on 06-23-2009 12:20 AM
(3,998 Views)
You can only pass strings into this property node (pink). What I would suggest is just to use the Number to Decimal String conversion VIs to convert your integer (blue) in to string. Then build a 1D array of these values and pass it to the Strings[] property for the Combo Box.
(3,944 Views)
