10-11-2018 09:06 AM
Actually accepted the solution too quickly because the best solution actually comes from mcduff where i can at least use the same 2 outputs with only the top input wired.
LabVIEW 2018 needed to view llb. The save top previous doesn't seem to work with the specialization structure.
10-11-2018 09:16 AM
wiebe@CARYA wrote:
BTW, one last thing. AFAIK, that "trusted enthusiast" is fixed by the forum. Didn't pick it myself.
I know 😉
wiebe@CARYA wrote:
For me, this one applies (to me, just to be sure) really well: arguing with an engineer...
I love mud! 😉
wiebe@CARYA wrote:
Cheers. If we ever met, I'll buy you a beer (drink it myself if you don't want it
I will buy the second and third rounds 😉
wiebe@CARYA wrote:
As for the language nuances, guess you're right. English isn't my first language, so I didn't realize that. Not sure if I can prevent that in the future, nuances take a long time to sink in.
And of course the devil is always in the details 😉
P.S. I will do some introspection...i am not supposed to blow that hard for so little...or am I !? ![]()
10-11-2018 09:17 AM
I wink too much also ![]()
10-11-2018 09:25 AM - edited 10-11-2018 09:30 AM
So earlier that type specialization structure got converted to a disable structure? That explains a bit
2017 has those TSS, but there are hidden and discouraged. So that's probably why they are disabled for save to previous.
Then again, if I replace the disable structure with a type specialization structure, I can wire two different types to the .vim. Not sure if that's desired behavior? EDIT (Again): that's why I though the select would be needed, to force two matching input types. Doesn't work well, as the input will retain it's type when nothing is wired.
10-11-2018 09:29 AM
wiebe@CARYA wrote:
@jacemdom specialization structure got converted to a disable structure? That explains a bit.
Reality is a messy business
That's why i never hold grudges ![]()
10-13-2018 04:46 PM - edited 10-13-2018 04:48 PM
So, we now are learning more about the pallates. And playing nice.
Let me chime in with an idea... I can be wrong and do not have LabVIEW loaded on my droid to check it out.
I haven't spent any time on the 2018 new enforce data type vis. Inside a TSS they might offer some powerful insights ... are they open or locked?
10-15-2018 03:01 AM
Sorry Jeff, still in 17SP1...
10-15-2018 04:06 AM
The VIMs on the Assert type palette are all unlocked but there isn't much to learn from them as they are pretty basic. The most interesting thing I saw there is this :
The use of 2 type assert nodes to always breakup the code. Nice trick but a simple always break node would probably be faster, quicker and clearer.
10-15-2018 04:06 AM
@jacemdom The use of 2 type assert nodes to always breakup the code. Nice trick but a simple always break node would probably be faster, quicker and clearer.
If it existed of course! lol
10-15-2018 06:04 AM
@jacemdom wrote:
@jacemdom The use of 2 type assert nodes to always breakup the code. Nice trick but a simple always break node would probably be faster, quicker and clearer.If it existed of course! lol
How about any function? Increment, Decrement, Add, Subtract, Multiply,etc. They all break when nothing is wired to it. Put one of those (unwired) in the last case, and I think you'll get the same effect?
