Mass Flow Meter
Here is what the manual says.
This would indicate to me that you have to talk to the device and get a responce.
Tim
GHSP
Message 11 of 14
(970 Views)
K ten lemme go thro the protocol structure and let you kno!!!
Message 12 of 14
(968 Views)
As told by you could you please attach any examples on RS 232 connection for this MFC or anything tats related!!!
Message 13 of 14
(964 Views)
NI has an example in the serial communication. If you go to help see attached: I do this as you may not be in the same version of LabVIEW and it is good for you to find these things yourself so that you how to do it in the future.
Then select the search function and type serail and hit enter select the serial and the examples are right there.
Let me know how this works for you.
Tim
GHSP
Message 14 of 14
(963 Views)
