Maximum Array Sizes
An array can have up to 2^31 elements per dimension (not 2^32 as claimed).
Message 11 of 13
(1,352 Views)
I've eliminated the need for queues now but I'm still getting approximately half of the points on the RT, despite no overflow on the FIFOs and only taking one point at a time on the RT. Any suggestions for what is causing this?
Message 12 of 13
(1,339 Views)
You probably need to provide more information.
  • How does the code with the eliminated queues look like? There are millions of way to either use queues or not use queues, so you are not really narrowing it down.
  • What is "half of the points"? (truncation at half max size? Every other point? etc.)
Message 13 of 13
(1,321 Views)
