Measure offset and gain error of ADC
HI.
I have an array of data from ADC (sinusoidal signal was applied to the input). Is it possible to calculate offset and gain error from this array? Thanks.
(3,594 Views)
Yes, that is possible. Providing you have the original input level of course, or you'll only get an amplitude, not a gain.
Details will vary depending on the exact requirements.
I'd use a (PtByPt) FFT. That would give you a DC (at 0 Hz) and a peak at the sinus frequency representing the gain. There are probably specialized tone analysis VIs as well...
(3,579 Views)
I don't think that FFT is need to use. Most likely should be used mathematics.
(3,577 Views)
Isn't FFT mathematics?
It's not about 'need' to use, for me it would be the easiest and most intuitive way to make it.
(3,561 Views)
So how from FFT get this parameters if all data in FFT is dB?
(3,556 Views)
FFT PtByPt.vi doesn't return dBs...
(3,551 Views)
