microphone level control
Hi everyone,
I am  a new LabView user. I have a testing equipment that uses USB-8451 USB to SPI Interface. And I am trying to adjust the microphone (Audio device) level to 100%. How do I do that?
Message 1 of 17
(5,451 Views)
@LV2020 wrote:
Hi everyone,
The audio device of the PC?
Or is the SPI device an audio device? If so, that might be a question for the chip manufacturer. At least, we would need a SPI device number, AFAIK. It's probably in the chip specification as well.
Message 2 of 17
(5,410 Views)
When I connect the test equipment to the PC, it is displayed under Audio inputs and outputs in device manager. It also displayed under sounds, recording tabs. Please see attachments. The testing equipment is using USB-8451.
Message 3 of 17
(5,391 Views)
Hey jbaqadi,
    Is the USB 8451 being recognized as an audio device?
     Or are you going to communicate with a device that has an SPI interface with the USB 8451?
If it's the first one, make sure to have the 845x driver installed on your computer.
Message 4 of 17
(5,365 Views)
cdiaz95
When I connect the testing equipment to the PC, device manager displays the following:
1. Under "Audio inputs and outputs" : Microphone (6- USB Audio Device).
2. Under NI-845x Device: NI USB-8451.
see attachment
I already installed 845x drive.
The first step I did is being sure labView is recognizing the USB connection, but I do not know which functions test the microphone level.
Message 5 of 17
(5,357 Views)
What do you expect to happen when you adjust the audio levels of the USB-8451?
AFAIK, the USB-8451 is not a sound device. I don't think it will do much good.
Message 6 of 17
(5,325 Views)
Please see this web page
https://www.ni.com/en/shop/hardware/i2c-spi/model-usb-8451
This is not an audio Device... There is no microphone in that USB device.
Benoit
Message 7 of 17
(5,322 Views)
I have butter understanding now.
Basically my test equipment have USB-8451 and an audio device (microphone AK5370).
I was able to get my LabView to recognize USB-8451 by installing theNI- 845x.
Now I need to test the microphone level for AK5370. There's is no driver related to AK5370. How would I test the microphone sound level for an audio device that does not have driver in LabView. Is it possible?
Message 8 of 17
(5,307 Views)
Benoit
Message 9 of 17
(5,300 Views)
Unfortunately, there is no native way in LabVIEW to set the volume of a microphone.
I suggest you to read the documentation of the audio device that you have. They might have a .dll to do. If not, you will need a wrapper from .net to LabVIEW.
Benoit
Message 10 of 17
(5,282 Views)
