microphone level control
Does the microphone even has an adjustable sound level? It might just sample, and then leave it to the software to adjust the signal. I'm not sure if there is a hardware gain...
If you can do it in Windows, you'll be probably able to do it through an API.
Message 11 of 17
(1,804 Views)
@bseguin wrote:
Unfortunately, there is no native way in LabVIEW to set the volume of a microphone.
I suggest you to read the documentation of the audio device that you have. They might have a .dll to do. If not, you will need a wrapper from .net to LabVIEW.
Benoit
@bseguin
Is there any way to access an audio device in LabView using .NET without 3rd party software?
Benoit
Benoit
What Assembly and Object do I need to use?
Message 12 of 17
(1,794 Views)
I know that it should be possible, but I never did that myself.
I prefer use DAQ since the frequency and precision are much better.
Benoit
Message 13 of 17
(1,780 Views)
you can try this to set microphone level.
/Peter
Message 14 of 17
(1,768 Views)
@pets wrote:
Dupe post
Then please post the link(s) to the duplicate post...
Message 15 of 17
(1,754 Views)
hi i posted the same thing twice so i deleted the last one and labeld it dupe.
should i name it something else?
or can i delet it?
Message 16 of 17
(1,751 Views)
Usually when a duplicate post is reported, it refers to a new thread posted twice.
If you created a duplicate thread, you can get it removed by reporting it to a moderator (under options).
I did not know you could delete it yourself, but if so that would work too.
I see only one post, so I guess the "dupe post" was redundant and confusing. But never mind, no harm done.
Message 17 of 17
(1,743 Views)
