Thanks for your help!
I think that the new 3.1.1 driver may be the problem -- let me explain.
First, I uninstalled all National Instrument software from the PC. I then removed the PCI-1428 frame grabber board, downloaded the latest NI-IMAQ driver that you sent a link to and installed it on the machine. When I ran MAX it gave me the same error that I posted in the original message.
On a whim, I uninstalled NI-IMAQ 3.1.1, removed the PCI-1428 card and installed NI-IMAQ 2.6. It worked. Using the old NI-IMAQ 2.6 driver I was able to snap and grab images.
I then reinstalled NI-IMAQ 3.1.1 over top of NI-IMAQ 2.6 to see if it would work, and as I predicted, I could not load my camera file, or any other camera file, using the new NI-IMAQ 3.1.1.
I'm running WINDOWS XP Professional, on a 3.2 GHz processor with hyper-threading. I am using a 300 watt continuous power supply with advanced power management.
Do you think the 3.1.1 driver is the problem?
