‎02-17-2008 10:09 PM
‎02-18-2008 01:55 AM
Can you attach you VIs? It will be easier to help you.
‎02-18-2008 01:28 PM
‎02-18-2008 04:35 PM
‎02-19-2008 03:27 PM
‎10-07-2014 03:42 PM
Hi there,
I am a beginner in LabVIEW. I use LabVIEW 8.6 and I am facing the same issue. I am trying to read AC current signal from a lock-in amplifier through a BNC board connected to PCI 6221 interface. However, by using DAQmx and virtual channels, I get a constant read out. The test bench in NI MAX 2012 can read the AC signal as shown in the amplifier. It would be a lot of help if you could help me out here.
Thanks in advance,
Karthik.
‎10-07-2014 04:03 PM
Are you just reading 1 sample? What is the frequency of your signal? What is your sampling frequency?
