Measuring a temperature by thermocouple
@chakib77 wrote:
You're not helping me here .. anyway thanks for reading me
If you want help then you need to supply the information necessary to help. You have been told multiple times that we cannot debug a picture that hides most of the code. Upload the vi if you want help. Read the resources that I directed you toward.
Message 11 of 18
(1,586 Views)
Please attach the file ending with ".vi" extension. This VI file is called a source code in programming terms, similarly, in other programming languages, a source code file in C language is stored in a file with ".c" extension and a source code file in Python language is stored in a file with ".py" extension.
This file contains all the information about how you've configured your instrumentation to read the temperature using the thermocouple, it will help us understand what you're doing and thereby guide on the right path.
Just a screenshot is insufficient as a lot of the information is hidden from plain sight.
Santhosh
Soliton Technologies
Message 12 of 18
(1,581 Views)
Here attached the file
have a good day
Message 13 of 18
(1,573 Views)
I'm sorry I haven't read the last message maybe because of the tiredness, I always get into the forum at 1am, after finishing work
here attched another VI
and if you want I have a video i'll edit it so that it doesn't took too much space and i'll post it
Tell me if there is anything else you wanna know
Thank you
Message 14 of 18
(1,570 Views)
have a good day
Right click on your Y-Axis and select Autoscale Y then run the program and see if that fixes the problem.
If that doesn't fix the problem then, without exiting the program or resetting anything, right click on the chart and select Data Operations>Make Current Value Default. Save the vi and upload the new version.
Also, have you verified that there are no problems with the thermocouple itself? You can do this by disconnecting your thermocouple from your DAQ and connecting it to a thermocouple reader.
I see no immediate fundamental flaws in your program, although I still suggest reading the link that I previously sent about using DAQmx functions. You have a lot more control over the data if you use standard functions, and it's really not that hard.
Message 15 of 18
(1,554 Views)
I've tried the first tip previously, but it doesn't work
I'm going to try the second one, but what will I upload exactly ? Here are the steps : I should go to Data Operations > Make current value default, save the VI then try again is that that you mean ? because I don't understand what should upload.
Yes I worked with many k-type thermocouples. I tried to change the channels and see if the software can detect it or not, then it works perfectly because when it is connected to the module I receive such a notification in my computer that shows that the device is connected
Another question if you permit, should I read all the link or only the part related with DAQmx?
Message 16 of 18
(1,541 Views)
Accepted by chakib77
If you set default values and save the vi the data will be contained in the vi and we can see what you are getting. So once you've saved the vi with the default values set upload the same vi.
I think there may be a "lost in translation" error here. Are you saying that it works perfectly if you select a different channel on the card? If so then perhaps there is an issue with that channel on the card.
You can skip over the DAQ Assistant section, but the rest is totally DAQmx. You don't have to pay attention to the .NET and C/C++ sections. It's really rather short so it shouldn't take you long even to read all of the sections.
Message 17 of 18
(1,537 Views)
I think there may be a "lost in translation" error here. Are you saying that it works perfectly if you select a different channel on the card? (Yes exactly)
Okay tomorrow I have an appointment with my supervisor and I will do what you have asked me
So thank you so much
Message 18 of 18
(1,522 Views)
