Merge 2D pictures
Trying to reproduce @wiebe's example
What is the name of the function used to transform the cluster and color box into a picture?
Message 11 of 19
(1,030 Views)
Message 12 of 19
(1,023 Views)
I found it, it's the Draw Rectangle.vi
But now I have another question:
I'm using the "Get Image" invoke node to get image from two 2D graphics in the Front Panel
How can I merge these two images into a single png file?
Message 13 of 19
(1,022 Views)
It depends from what you needed. How to "merge" - side by side, or something else? Try to draw both images into single picture, then convert it to Pixmap, then save to PNG using Write PNG File, that is.
Message 14 of 19
(1,019 Views)
Yes, I want to get both XY Graphs in a single .png file, one above the other like in Fig.1
Fig. 1Fig. 1
LabVIEW can export one graph using the instructions "Get Image" + "Write PNG File.vi" (Fig. 2). This process it's very simple and uses only one wire.
My initial questions are:
1. Is there a way to combine the "Image Data" of both XY Graphs?
2. Or do I need to use the Invoke Node "Get Image", convert the "Image Data Cluster" using "Unflatten Pixmap.vi" (Fig. 3) before anything else?
Fig. 3Fig. 3
Message 15 of 19
(1,001 Views)
The simples way to do this is something like that:
In horizontal direction will be a little bit more complicated, but also possible, of course.
Message 16 of 19
(985 Views)
And this will work in assumption that you have exactly the same width of the both graphs. If not - then you have to copy line by line and fill the gap on smallest graph.
Message 17 of 19
(974 Views)
Maybe you could put both graph on a Tab control, and call Get Image from the Tab instead of merge 2 images.
George Zou
Message 18 of 19
(951 Views)
Using this the file (export image to EPS) size coming 30 times larger. I would like to combine two pictures to one picture with around 100kB size.
How that can be done ?
"concatenated": 83kB
"pixmap": 2906kB
See image below
Message 19 of 19
(623 Views)
