03-16-2010 10:43 AM
I ran the profile tool on your program. It shows the TDCluster AE.vi running almost a million times. I do not see where it is called that often (or why). Even though it is fast (average time ~ 1 us), the total time still adds up to about 2/3 of the total run time. For this test I started the main VI, clicked Set Parameters, clicked Accept and Solve, then clicked Stop. Total program time is about 1.2 seconds. The AE time is about 800 ms.
Lynn
03-16-2010 10:51 AM
Two things:
Where/how do I get/use the vi profiler?
And I too have no idea why it would call that vi that many times. The laggyness is far worse when dealing with an input function.
The input function portion I am still working on though, so I am hoping that it's getting better.
03-16-2010 11:29 AM
Tools >> Profile >> Performance and memory.
Also, if you post a later version of your program, please include some values of the System parameters which will produce a non-trivial result. The ODE display shows NaN as the coefficient of x when I run it with the default values.
Lynn
03-16-2010 11:45 AM
krwlz101 wrote:
One more question (for now), is there a way to get an initialize, or first run type of event? As one could assume from my last post, I have some AE's storing data for me, and wanted to add an initialize case, so that I could use that to set some defaults. I would only want it to run the first time though.
Sorry I've been too busy to keep up- I'll post back on the code later. But I did want to point you to the "First call" function. It is a good function to use to make sure your first call to an AE initializes the data.
03-16-2010 12:16 PM
krwlz101 wrote:Two things:
Looks GREAT! Two minor hits though.
03-16-2010 12:29 PM
Jeff,
Thanks for point 2. I had noticed the default tunnels but had not followed through with the consequences.
Lynn
03-17-2010 12:43 PM
OK,
I am really not sure which tunnel in the consumer loop you are talking about.
What I think you are saying I need to do however, is add a blank state to the state machine?
Or is it the top tunnel in the producer loop that is the issue? The one that only fires a command in one event?
03-17-2010 01:22 PM - edited 03-17-2010 01:23 PM
krwlz101 wrote:OK,
Or is it the top tunnel in the producer loop that is the issue? YES The one that only fires a command in one event?NOPE it fires every event
It fires a command it EVERY event- you cant have a blank value in a tunnel so, when you "use default when unwired" you do get a default value. In this case it fires a RSD command from every event exept the one you wired a contstant to.
The better solution is to enqueue indide the event structure- That way a different number of commands could be fired from each event.
03-17-2010 01:38 PM
I originally had coded it with the events inside the consumer loop, and though that it was poor coding, since the consumer loop was producing events.
I will probably revert to that, since it seems much simpler and straight forward.
03-17-2010 01:40 PM
