03-16-2014 05:01 PM
Not so often... but is it a reason ?
Was just wondering if I was missing something... visibly not. 🙂
 Dennis_Knutson
			Dennis_Knutson
			03-16-2014 05:08 PM
03-16-2014 05:17 PM
Well, since it's done...
By the way, any idea of how forcing LV to reload its menus ?
For example, I add an item in the LV help directory or projet directory and I'd like it to appear in menus without re-starting LV...
 Dennis_Knutson
			Dennis_Knutson
			03-16-2014 05:22 PM
03-16-2014 05:27 PM
This is for palette no ?
 Dennis_Knutson
			Dennis_Knutson
			03-16-2014 05:36 PM
 tst
			tst
			03-17-2014 04:20 AM - edited 03-17-2014 04:22 AM
Some of the options in LV are exposed as properties, like you said.
If you want, there are also VIs in <LabVIEW>\resource\dialog\lvconfig.llb. I never really played with them (and I really don't feel the need), so I don't know if they affect the config immediately, but I think they do at least save to the INI file immediately.
As for updating, there should be refresh methods for both the palletes and the menus in the Application class, depending on your LV version, but the pallete one at least has been there for at least a few years.
03-19-2014 04:33 AM
thanks Tst. By the way those kind of things could be a part of the Hidden Gems library.
Regarding the refresh I saw effectively a method to refresh palettes but not menus.
