Missing Sub VI's when opening LabVIEW file
When I go to open my main VI it is unable to find several Sub VI's, but the missing Sub VI's are supposed to be installed with NI-DAQmx which is installed. Some of the missing Sub VI's include 'DAQmx Read', 'DAQmx Start Task', 'DAQmx Stop Task' as well as a few others. I have tried to open the VI using both LabView 2013 and 2014 and have had the same problem with both. Any help is appreciated.
(3,404 Views)
Accepted by jyan94
Did you install DAQmx after installing LabVIEW?
Did you select LabVIEW support when installing DAQmx?
(3,398 Views)
And verify that the version of DAQmx is compatible with your version of LabVIEW. You didn't provide this vital information.
http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248
(3,390 Views)
I re-installed the DAQmx software and included the support and that did the trick. Thank you Altenbach
(3,384 Views)
