04-05-2009 06:51 AM
Is it possible to open a new front panel from the main vi on the PDA target, created with LV Mobile module?
I like to press the button in the main vi, and open second vi with the new front panel and new controls and indicators.
Thanks.
zdenko.
Solved! Go to Solution.
04-05-2009 10:30 PM
By the word 'new window' you mean to say you are trying to call a subvi?? If so that is possible. Place the VI as a subvi and modify the "subvi node setup" so that the sub vi Front panel opens.
But if you are looking at opening a non existant vi i.e. creating a new vi dynamically it is not possible. In LabVIEW environment VI templates solved this problem but PDA does not support *.vit's
Post back for queries.
04-06-2009 02:00 PM
Thanks.
Works perfect.
Zdenko.
