Modbus RTU. Error 6101 occurs by reading from PID controller
could you please post the code you are using currently? I would like to take a look into it.
Best,
Melanie
Melanie Eisfeld
Senior Applications Engineer, National Instruments Germany
Certified LabVIEW Developer
Certified TestStand Architect
Message 11 of 18
(2,340 Views)
Hi
The document doesn`t help unfortunately.
I am attaching the code which I am using but it hasn't changed a lot since my first post.
Lukas
Message 12 of 18
(2,303 Views)
Hi stiefel,
try to initialize the boolean value you are passing to the function MB Serial Master Query Read.
Maybe this might generate the timeout error.
Kind regards,
Pep
Message 13 of 18
(2,266 Views)
Try reading Holding registers instead of input registers.. Also use a bundle by name for your cluster.
Message 14 of 18
(2,244 Views)
Hi
Thank you for your help. I rebuilt the program as Dave has mentioned and still get the
error -1073807298 ocurred at VISA Read in MB Serial Receive.vi:3-> MB Serial Master Query.vi:2->PID-Read.vi
Possible reasons:
Visa: (Hex 0xBFFF003E) Coud not perform operation because of I/O error.
I get this same error using the set_temperature.vi and it still sets the temperature correctly. The controller also shows a little light indicating communication over the interface when running any of the programms.
So the same error as before which I have mentionend in Message 9. Any suggestions how to resolve that problem?
Regards
Lukas
Message 15 of 18
(2,201 Views)
Have you tried increasing the timeout value? What is it set at? Also is your address the same for unit ID in the controller? You can by sending a broadcast "Unit 0" and all will except the values for setpoints (Writes) but if you request data from a controller and it does not have the same ID it will not respond.  The slave Address must be the same as what is set in your controller.
Message 16 of 18
(2,193 Views)
The timeout value is set to 10000 and I have tried increasing it but it doesn't make a difference. Anyway I am not getting a timeout error right now.
The slave address of the controller is set to 2. When I am using the programm "Simply Modbus Master" communication works fine.
Thanks for your efforts.
Message 17 of 18
(2,179 Views)
If you can use a different controller Automation direct has a good selection. I use Automation Direct Solo temperature controllers with the same NI modbus library and it works very well.  Automation direct makes a modbus serial to modbus Ethernet gateway. It works very well. This eliminates a lot of the serial port problems with converters and also allows for setting up polling of slaves in the gateway.
Message 18 of 18
(2,161 Views)
